BatCap 800 and 1/0 Wiring
I just got this out to measure for someone who is asking about it, and I want to clarify that while the wire is in good shape, it was attached to the frame under my car, so there is some grease/dirt on the wire and a bit of discoloration in some spots. If you're looking for show quality wire, this isn't for you. If you need wire that's in good shape (without knicks/cuts) and works perfectly fine at a good price, this is it. Also, it's just over 15.5' for each wire...not quite the full 16' I had thought. I do have some shorter pieces that are like new as seen in the pic above...maybe 2-4 sections of both colors. Also have large and small fuse holders and fuses if needed.
RCobra07
RCobra07
Orlando, Fl
lionfamlee
