Bass stopped working on right side speakers months after installing new Pioneer four-ways in back
Canoeman
Hi I am new to this forum and no next to nothing about car audio. I have a 1999 Toyota Camry with the factory CD player and radio. One of my rear speakers went out so I replaced both with Pioneer four-way speakers. I thought I had everything wired correctly and it sounded great for about six months. Then I noticed that the bass had dropped out of not only the new rear right speaker but also the original right door speaker. I have not yet tried switching the speakers, but I did switch the wires on the right rear and it did no good. Did I blow something in the stereo? Thanks
If you can get a multimeter, test the resistance on that new 6.5. It should read what the spec sheet claims. More than likely 4ohms. Most oem radios play at 4ohms on the voice, so I do not believe you under loaded it. The fact that they are still getting power means that you still have a full spectrum signal.
4 ohms is the impedance under load, so the non-load resistance as read by a multimeter will be between 2/3 and 3/4 of the rated impedance. The actual reading is entirely dependent on the temperature. For 4 ohms it should read between 2.66 and 3 in other words.
An easy and lazy way to test speakers is to touch a 9v battery between the terminals, AA and AAA work too (or a diode test mode on a multimeter). There should be cone movement (don't hold the battery on there, you're just looking for movement with some quick taps). If not use a multimeter to measure the resistance between the leads as 1aespinoza mentioned. A faulty speaker can either be OL, super high, or far lower than rated, like under half. If it reads good then you should check your wiring. Car speakers endure a lot of elements, so it's pretty common for the terminals to corrode to the point they don't play. If you used an adapter that should be reconnected too.
I always wondered why even new subs would not read their listed resistance. 4ohns would always be berween 3.3 and 3.8. 3ohns between 1.8 and 2.9. I attributed it to meter battery being low but when I touch leads to each other it is zero.
But on that note, I notice mids and highs are usually only .1 to .2 ohm off target. (Cue in School House Rock intro track) Now I know.
Maybe voltage loss? I always set my LFP to 80 and on steeper slope with no noticeable SPL loss. Playing a sine wave is a lot easier on your...
370
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
560
Canoeman
Canoeman
Asheville NC
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
