90MaximaSE
To get a good front soundstage, most of us are stuck with putting relatively small 6-1/2" (or smaller) drivers in the front doors. Speakers in Kick Panels just don't cut it in my experience. I'm going for 6.5" Component sets (with crossovers and separate tweeters) for the build I'm working on: My 1990 Nissan Maxima SE.
To get decent Bass out of door speakers, for sure the speaker enclosure MUST be air tight AND well dampened. This is a tough proposition for a car door, and you can spend an TON of effort and $$$ on Dynamat products to do this properly. Just take a good look at the Sticky "Proper Door Sound Deadening and You" if you disagree. Plus, you have to worry the effects of water coming down past your window seals: electrical corrosion of connections and voice coils plus degrading of speaker cones.
Seems to me you can avoid a lot of effort and $$$ by a llittle planning and fabbing a small custom enclosure for the mid-bass driver from MDF, which is pretty easy to work with (fiberglass isn't that bad either). I'll guarantee that the ability of small rigid enclosures to give great bass from small speakers is vastly underestimated by most DIY car audio people. You see this in computer speakers alot.
The biggest example of this is what Bose has been doing with their factory systems for Nissan and GM for decades - and it's been right underneath my nose. After listening to my Bose system (now Kaput) in my Maxima for years , I was flabbergasted when I finally saw what was in the F door pods: a little weiny plain jane 4" paper cone speaker. These produced GREAT Bass. Here's a photo of this F door Nissan-Bose Box:
Currently I'm working on a custom box for the Polk MM6501 series 6.5" driver that will bolt into the same place the Bose enclosure did. The crossovers and tweeters WON'T be inside the doors. I already have 6.5" MDF adapter plates, and may just box those in with more MDF. There's more available space in my doors for added volume, so I've been playing with the WinISD speaker box design program.
Any one else our there tried this approach?
I'd like to know the enclosure volume you used for specific speakers if so.
There's great potential here to save a lot of money and hassle with subwoofers and buku amp power. Unless you're just hell bent on vibrating the teeth out of anyone sitting next to you at a stoplight.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
