bass NOT HITTING hard.. wat could it be??
blackkila.gtr
so im still working on my system and ive been tryin to solve this power issue, the bass hits hard when the car is just starting to run and then it doesnt hit as hard anymore once its been runnin for a lil
this is how i have it setup..
..ight from the main battery i have a 4guage wire that run to the 200amp relay from that to the second battery from the second battery to a power distributer then 4gauge wire to one amp and another 4gauge wire to the other amp..
try taking the relay out it may be opening the charging circuit to the back bat. you really dont need a relay unless you plan on playing your system for a good while with your car off
just sounds like your battery is draining quickly. whats your system consist of? sounds like you need to check your ground, upgrade your battery to a dry cell, consider doing "the big 3" (theres a sticky in the electrical section about it).....if none of that works youll want to consider upgrading your alternator.
get a better sub //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif:rolleyes://content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
ok im running an optima redtop to a dry cell stinger battery the amps are both hifonics and the sub is a 15 l7..i was thinking of a cap but would that really help??
if you are running both those batterys then your wiring sucks or your alt isnt nearly strong enough.
check your wiring cause something doesnt seem right.
blackkila.gtr
blackkila.gtr
Nevada
J31Rob
