Bass keeps cuttin out wjile drivin then comes back on?
my bass keeps cutting out while in driving down the road then it will turn back on and go off and on but only does it everyonce in awhile but everytime im driving? and suggestions on wats going on?
loosewiring? check your ground wire, voltage dropping too low? rem wire is loose? try testing these first...
are you using a capacitor? my first system i was using a cap and had same issue, turned out that an internal bolt had a stripped compartment and would cause this to happen.... when i removed the cap all was good... soldered the peice together and worked fine... sold the cap later on for better wiring //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Edit:
troubleshoot. There's a million things that could be wrong
this x 9994593945
inspect all the details of your install something went wrong there if your lucky if not then could be issues with your amp...
i was using a cap then had other problems wit it so took it out. and i have a memphis wiring kit. but my screw for my battery supply is a lil striped think that could be the problem?
hmm try wiggling the power wire see if it moves around.. could be an issue but if its holding tight i dont see that as being a problem.
Fresh Ta Def
Fresh Ta Def
Gallup New Mexico
I Like Waffle
