Sold Banda Viking
psychoacoustics
hammer and the evil one
here it it the loudest amp in the world!
this amp is actually out of Hal's car right after the last run of world finals S.America
installed
in the box ready to ship
the led in the above pic is now inside of the case it was externally re routed to see if it is on or not due to the mounting in Hal's car
test results
http://audioforum.termpro.com/topic/20/14528.html
http://www.caraudio.com/forum/showthread.php?t=439447
homepage
http://www.bandaaudioparts.com.br/ingles/home.html
the gain has been super glued but im sure it will come apart with a little secret sauce.
shipping to anywhere in the us 1300
sick amp..
sick price..
bump for the coolest guys around.
deal with them in confidence //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
all of the specs are on bandas website but around 7.5k with 5 batts at .5
the gain is on the top of the amp in the black strip down the center of the amp its noy on an end like most amps
so if you see the first pic there are 5 amps visible but 4 are hidden so you would need to remove amps to adjust them if it changed or moved from vibration.....a bad think at 181db
so its just precautionary thats all
this made 300 watts less than the stetson 14kd in thorshammers car at .5 but was .3 louder
inside the amp there is a 100 amp fuse on every power supply right off of the rail if the amp gets shorted or anythingn happens that might cause it to blow the internal fuse blow very slick setup
psychoacoustics
psychoacoustics
Buffalo NY
psychoacoustics
