Azentek Atlas CPC-1000 Double Din Car Computer All-In-One 1.83 GHz, Intel Core Duo 7"
This item is like brand new. amazing unit, it is a windows computer but in a headunit, its amazing if you are trying to pimp out your car big time!! has a 120GB hard drive, supports gps, bluetooth, wifi, dvd, cd, aux, usb, ipod, iphone, whatever..it operates like a computer with windows. The wifi you can sit right next to mcdonalds in your car and surf the web. This item is very rare. I do have almost everything it came with. I dont have the gps antana. Or the rca out puts but i went ahead and created the rca cables for the unit as you can see in the pictures and it works amazing.
1100 OBO.
Free.
Specs: Processor Intel Core Duo CPU L2500 1.83GHz, 32 kb Level 1 Cache, 2048 kb Level 2 Cache
Display AU Optronics 6.5" LCD Display with Touch Screen
LED back light. Max brightness 550 nits. 10 nits minimum.
4 wire resistive touch screen
Ambient light sensor
Graphics Intel 945GM(UMA)
Memor 2GB DDR2, 533Mhz
Hard Drive 120 GB 5400 RPM, 8MB Cache Hitachi HTs542512k9sa00-(s1)
DVD Drive model number Teac Automotive Grade DV-SC150
Secondary Display DVI output for Rear Seat video or other application
Input methods Dual controlled Touch screen and mouse pointer on front screen
WiFi 802.11 b/g/ Wireless LAN support by Broadcom BCM94311MCG
Bluetooth Integrated broadcom 2.0
PCMCIA One Rear PCMCIA slot
GPS Integrated GPS with antenna - GlobalSat ET-332 - SiRF III chipset - GPS antenna built-in on vehicle body, reserve connector on chassis
USB 2.0 1 front mini-USB, 1 Front USB, 2 rear USB ports
Product Dimensions
Depth: Rear fan to metal end - 150mm (6-1/8")
Depth: Rear fan to plastic face front - 178mm (Knob extrudes additional 10mm)
Height: 102.2 mm (4")
Width: 178.4 mm (7")
Audio Sigmatel 9220 5.1 surround sound
Microphone Integrated 2 sensor array microphone
Amp 4 Channel amplifier
Freq. Response -3dB 500Hz-10kHz
AMP Peak power Output 50 watts
AMP RMS power Output 22 watts
Pre amp Outputs 5 Channel
AM/FM Radio Software controllable Radio US 88~108 Mhz
Memory Expansion Front USB port or SD memory card slot
Operating power / Voltage Range 9V~16V
Parasitic power load 0-26ma
Shipping details
Box sixe 9-5/8" x 8-5/8" x 6-1/2"
Weight is 6.5 lbs
RCA breakout cable
Green Line level output - Back Left
Gray Line level output - Center
Purple Line level output - Back right
Black Line level output - Subwoofer
Red Line level output - Front Right
White Line level output - Front Left
Enviormental Specifications
Storage Temprature -40c-85c
Operating Temprature 0c-40c
Vibration 0.8 Grms, Operational (10Hz~1000Hz)
ESD Contact 5kV and Air 10kV (No data is lost)
Inputs and Outputs
Rear I/O 1 Composite video output
16 pin power & audio interface connector (see wire label or pinout diagram for functions)
1 DVI
2 USB connectors
1 Line-in mini Jack
1 PCMCIA Cardbus slot (Type I) ENE CB714
1 GPS Antenna connector (Blue)
1 AM/FM Radio antenna connector (Black)
2 802.11 antenna connector (Purple)
Front I/O 1 Line-in mini Jack (Software switch to Audio Out)
1 USB
1 Mini USB
1 Array Mic
1 Critical reset (Small hole in front right middle)
1 Power/ volume Knob with center click
6 programmable buttons (Requires software developer support)
Right and Left mouse buttons
1 DVD eject button
1 Ambient light Sensor
1100 OBO.
Free.
Product Dimensions
Shipping details
Weight is 6.5 lbs
RCA breakout cable
Inputs and Outputs
1 DVI
2 USB connectors
1 Line-in mini Jack
1 USB
1 Mini USB
1 Array Mic
1 DVD eject button
