AVN 5510 video/nav ground.
dwc032
I know that this has been asked way to many times, but I have done a search and all I can find is that you need to just ground the parking break to make the DVD work. Is the Nav feature the same? What about the speed sensor wire? Does that need to be hooked up also? Or do you just groud the parking break wire and then il be good to go on dvd and nav feature.
Im sure this question has been answered a thousand times, but any help would be appreciatated.
ground the brake. the other 2 are not needed. If you are dead set on hooking it up you have to find your speed sensor wire and tie into it. As I said it's not needed.
Sweet bro thx! So just to reiterate, the nav will work just fine with grounding the ebrake wire.
dwc032
dwc032
Bend, Or
dwc032
