Sold Avionixx AXA 440.4, 4 chanel 440 watts rms
  • Thread starter SurgicaL
  • Replies 0
  • Views 478
SurgicaL
Used for 1.5 months. Cosmetically 9/10 Small scratches on the sides from screwing the wires in. not noticable unless you turn the amp on its side.
I'm upgrading so its time for this one to go....Original box and paperwork included
$150 shipped.
best budget amp out there.
Dont let the rating fool you (it is sorely underrated)
Class A/B amplifier
MAX Power @ 4ohm 2x440 Watts Bridged
RMS Power @ 4ohm,
RMS Power @ Bridged 4 ohm
RMS Power @ 2 ohm,
Power Bandwidth (Rated Power -1dB) 15Hz - 30kHz
Frequency Response (+0/-3dB) 5Hz - 70kHz
"A" Weighted Signal to Niose Ratio >-90dBA
Channel Seperation >60dBA
Damping Factor >200
Variable Input Level 150mV - 6V
Variable Frequency Bass EQ 25Hz - 80Hz
Controlled Electronic Noise Suppression "Cens" Yes
Variable Low Pass Crossover Filter 50Hz - 250Hz 12dB
Variable High Pass Crossover Filter 50Hz - 250Hz 12dB
Double Sided, 1Oz. Copper Clad FR4 board Yes
Overload Protection Yes
Short Circut Protection Yes
DC Off-Set Protection Yes
Thermal Protection Yes
Fuse 2 x 40A
Heat Sink Dimensions - Inches 13 7/8x 9 7/8 x 2 1/4
Heat Sink Dimensions - Millimeters 352 x 251 x 57
Weight 12 Lbs.
SurgicaL
SurgicaL
Va Beach
SurgicaL
