brand new. 150 shipped. lower 48 states only. paypal only.
Class A/B amplifier
MAX Power @ 4ohm 2x440 Watts Bridged
RMS Power @ 4ohm,
RMS Power @ Bridged 4 ohm
RMS Power @ 2 ohm,
Power Bandwidth (Rated Power -1dB) 15Hz - 30kHz
Frequency Response (+0/-3dB) 5Hz - 70kHz
"A" Weighted Signal to Niose Ratio >-90dBA
Channel Seperation >60dBA
Damping Factor >200
Variable Input Level 150mV - 6V
Variable Frequency Bass EQ 25Hz - 80Hz
Controlled Electronic Noise Suppression "Cens" Yes
Variable Low Pass Crossover Filter 50Hz - 250Hz 12dB
Variable High Pass Crossover Filter 50Hz - 250Hz 12dB
Double Sided, 1Oz. Copper Clad FR4 board Yes
Overload Protection Yes
Short Circut Protection Yes
DC Off-Set Protection Yes
Thermal Protection Yes
Fuse 2 x 40A
Heat Sink Dimensions - Inches 13 7/8x 9 7/8 x 2 1/4
Heat Sink Dimensions - Millimeters 352 x 251 x 57
Weight 12 Lbs.
al
Class A/B amplifier
RMS Power @ 4ohm,
RMS Power @ 2 ohm,
Damping Factor >200
Fuse 2 x 40A
Weight 12 Lbs.
al
