Avionixx 800.2 or Memphis ST1000D
ppersonally i'm partial to memphis after useing several of thier amps (including the 1000D) and the they are very power efficent for thier size and clarity.
also if you gowith a memphis 1000D get the 16-MC1000D and NOT the 16-ST1000D. The 16-MC1000D are the newer "Mclass (if that means anything)" models and after working with both older and newer mehpis models both mono and 4ch's i think the newer models are betterin terms of both power efficency and durability (man i beat the crap out of my memphis //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
The Avionixx is a solid amp for the price, I used to own one.
My only complaint with it, and the reason why I didn't keep it, is because it's only stable to a 4 ohm mono load at full power. So it's limiting as to what drivers you can use with it...
Doesn't the memphis put out max power at 1 ohm? That one should draw more current and *should* have more distortion, not that it would be noticable. I'd rather have 800wrms at 4 ohm than 1000 at 1 ohm. This would be a dual 2ohm sub its going to?
hdave
hdave
Toronto, Canada
geezy21unc
