Southeast Region August 5,2012 Newport News, VA
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
What's these name tags you speak of
If I get a parking pass I will be able to have my car for the school year. If not I will be stuck with leaving it with my family.
oh ok. yeah you need that. if not borrow mine........
Has everybody decided on going to chesapeake? My alt is almost in just need some new valve covers for clearance issues.
well if there stock you might be able to bolt it to a board to keep it's shape and then carefully re-shape it using a hammer and block to obtain the clearance needed.
They're really thick aluminum highrise valve covers I just found a set of stock ones so I think those should fit. I just hope my rockers have clarence. I tell you witt car audio if it's not 1 thing it's another
I am. I'll be there around 1030-1100
Roger that. i will be heading out as soon as i get my batteries hooked up and get the car started. i hope to be there around 10:00. i havnt even started my car with the new valve covers and alt. i pray to God my rockers don't hit. i'll be driving a white 92 Camaro. Who else is going? Rebel?
Jaydub and I should be there around 11. Still have not found much on the show. Entry fee? Classes?
@rebelfromva if you can bring that bat with you and ill pick it up from you there. i'll bring my tools to try to fix it( after i buy it, i'm not gonna mess with something i haven't paid for). what size are the bolts for the deka's?
You might be the first there--save some spaces, I drive a gold CRV
DC said he thinks it's $5 to get in, and probably $10 to meter.
I left it in Richmond bc I didn't hear anything.
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
674
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
JayDubb757
JayDubb757
Hampton, VA
JayDubb757
    May 16, 2024
    May 16, 2024
