Sold Audioque AQ2200D $310 Shipped
cmobley
This is my Audioque AQ2200D. It works 100% and is 9/10 cosmetically. It has a few very minor nicks and scratches around the mounting feet. I upgraded to the AQ3500. It has been run at 1 ohm the entire time Ive had it. The bass knob is not included because the 3500 didn't come with one. I don't play when it comes to shipping. Shipping will be same day if possible. Any questions ask.
No trades at this time.
$310 Shipped
Specifications
Model AQ2200D
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Remote Level Control
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V 2500 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71″(L)x9.27″(W)x2.35″(H)
cmobley
cmobley
Cleveland, Ohio
PioneerSPL1990
