Audioque AQ 2200d
Budget_Ballin'
TEAM DC
Audioque AQ 2200d
Item is used but still in great working condtion.
Cosmetically 8.5/10 scratches on bottom and feet from mounting and a few scratches on the amp, nothing major.
Mechanically 10/10
Specifications
Model AQ2200D
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V 2500 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
$330/shipped
Amp will have the bass knob w/ clip light, but no cord.
I've never had it at .5 ohm but I know quite a few people that do run it at that and they're very happy with what it puts out. I def do know that. I'd say it would. They're very efficient and solid amps. If you'd like to talk more or get it, txt me at 740-222-1888.
Budget_Ballin'
TEAM DC
Budget_Ballin'
Southern Ohio, United States
Budget_Ballin'
