Audioque 2200
cal
A.Q. 2200
used, amp has been refurbished and is in fully working condition, very little cosmetic and the worst is on the bottom plate, imo amp looks very clean . no visable burns on the board. amp does not have original box or remote but will be packaged well for shipping
SPECS
Digital Monoblock 1 ohm stableInput
Sensitivity0.2v-8v
Variable Low Pass Filter20Hz-200Hz @ 24dB/Oct
Subsonic Filter10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Clipping Display Led
Signal to Noise Ratio90dB
External Fuse Rating200 Amps, 400 Amps Linked
Tested Voltage14.4V
4 ohm power @ 12V @ 1%
THD500x 11 ohm
power2200 x 1 1 ohm
Power @ 16 V 2500 x 1
2 ohm Linked power @ 14.4V @ 1% THD4400 x 1
Dimensions17.71"(L)x9.27"(W)x2.35"(H)
325 shipped con u.s. price drop 300
no trades
^you see my amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif get the big aq
yes. i ran the 3500.1 great amps, if i find 2 of them resonably priced i might just run them. to be honest tho i have a hard on for b2 audio atm .
final price drop 275 shipped because i had the back cover off ant it got a few more scratches, updated last pic to show the scartches
cal
cal
cal
