Audioque 2200 cheap...
cal
AUDIOQUE 2200D
used, amp has been refurbished and is in fully working condition, very little cosmetic and the worst is on the bottom plate, imo amp looks very clean . no visable burns on the board. amp does not have original box or remote but will be packaged well for shipping
SPECS
Digital Monoblock 1 ohm stableInput
Sensitivity0.2v-8v
Variable Low Pass Filter20Hz-200Hz @ 24dB/Oct
Subsonic Filter10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Clipping Display Led
Signal to Noise Ratio90dB
External Fuse Rating200 Amps, 400 Amps Linked
Tested Voltage14.4V
4 ohm power @ 12V @ 1%
THD500x 11 ohm
power2200 x 1 1 ohm
Power @ 16 V 2500 x 1
2 ohm Linked power @ 14.4V @ 1% THD4400 x 1
Dimensions17.71"(L)x9.27"(W)x2.35"(H)
275 shipped con u.s.
only trade is for a minty pioneer deh-p880prs
cal
cal
cal
