Audiopipe APCLE-18001D Amp Dyno
I think he was talking about the blip at the lower wattage range. Class D amps do that on the dyno. The amp dyno in Certified mode will keep going if the output is corrected to below 1% THD... which it does after the blip.
And yes it has a lot more power at 1 ohm between the 1% THD and the clip point.
[quote name='Jeffdachef']@BOOMINGRANDPAWhat was that you heard about audiopipe amps overheating/having heat issues?[/QUOTE]
it's what many peeps said even on the apcle but most where apmi
.. these look like the have vents on top so i would think they'd stay cooler.. it did great, can't believe it did so well @1/2 ohm.. sad we may have to start recing these over other amps but going by dyno is all we can do unless we have owned something a yr or more..
it's what many peeps said even on the apcle but most where apmi .. these look like the have vents on top so i would think they'd stay cooler.. it did great, can't believe it did so well @1/2 ohm.. sad we may have to start recing these over other amps but going by dyno is all we can do unless we have owned something a yr or more..
ryan put the amp through the worst tests possible for an amp and both his apmi and apcle amps stayed cool so something's wrong with other peep's sh*t.
These boards have proven themselves for almost 10 years. Great amps for the average user. Just dont run them .5 daily (At least i wouldnt) and have the power to use them and they are fine. The people that have complained about them being ****** are most likely 18 year olds with a 95 honda on a 60amp alt and 6 year old stock battery.
bigblank69
bigblank69
Eureka, MO
TheFiverMan
