Audiopipe ap-6002
Spldecendant
Ny
Has anyone tried out the audiopipe 6002 would it be a bad idea to run it at 2ohm on speakers? And I don't see a power light on this amp? The only reason I plan on running these is because the rms is perfect for my speakers and my buddy has an audio shop and can get me that 6002 for even cheaper then what's online
You're going to bridge it and run it at 2? I wouldn't do that... It'll probably go into protect when you crank it or you'll end up frying it. Why not just get a bigger monoblock?
It's for 2 4ohm door speakers wired in series per Chanel single voice coil 4 speakers in total so no they will not be bridge they will be at 2ohm per channel which it's rated for? Hows the sound quality going to be out of the amp like this? I'm not looking for focal quality but something pretty clean sounding
Audiopipe and clean sounding do not mix. They're made for making cheap power, not for quality.
Two four ohm speakers wired in series will not get you a 2 ohm load per channel. You will be wired for 8 ohms nominal. If you are intent on getting a two ohm load per channel you will need to wire each pair of door speakers in parallel. As was mentioned this probably isn't the greatest amp for your application but if you don't over drive it I am sure it will sound ok. I can't imagine that AP amp is actually doing its rated power cleanly if at all. What speakers are you running in your doors? Seems like an awful lot of power for four door speakers especially if we are talking about coaxials. Kinda curious what drivers you are using that are rated for 300 watts rms a piece as you said the AP amps rms rating matched your speakers perfectly.
I don't think it's a good idea to bridge door speakers anyway. And what speakers in your doors need 600 watts a piece? Seems a little excessive. And if you're looking for SQ out of fronts I'd go with something other than AP.
There 4 10inch crescendo mids what amp would work well?
Crescendo 10's what amp would you recommend then?
Spldecendant
Spldecendant
Ny
Spldecendant
Mike Mccabe
Giles
    Jun 27, 2026
