Well I'm looking at getting an AQ HDC3 18", and I was wondering if it could take 3000 watts, or should I get Dual 1 ohm and wire it to 2 ohms so it is getting 2000 watts?
with a D1 sub, you can wire it to .5 or 2 ohms. You will be getting 3000 watts. How did you get 2000? You will get 2000watts when you get a D2 sub and wire it to 4 ohms.
you all know that the new "revision" of the HDC3 will be out VERY SOON. Newly designed 8 spider pack, and a newer copper voice coil. DJ said it is much improved.
i run my hdc318 on a aq 2200d @.5 not too sure what that does (watts) never clamped it. and it does fine im sure if you set gains right you will be ok mine is also a copper coil getting ready to strap 2 aq2200's and see if it will blow i have a alum recone on the way.
I had customers call and say they burned the coils out on their HDC3's with SAZ-1500D's, but I think that's 3 hours of full tilt ridin round town probably with lots of clipping too....
