Sold Audiocontrol Overdrive 65 shipped
canyouhearmatt
#1 **** talker
65 shipped.
AudioControl created the Overdrive with one goal in mind — to ensure that your amp sees the cleanest signal possible. Many modern car stereos boast 4- and 5-volt preamp outputs, but they're rated at full output. Turn your stereo to a normal volume level, send the signal through a 20-foot cable, and your amps may end up with just a couple of volts. That's why AudioControl made the Overdrive.
Higher voltage = lower noise
The Overdrive line driver boosts the signal from your receiver up to 24 dB, right up to the maximum level accepted by your amplifier or processor. The high voltage level keeps the noise out of your system, while feeding your amps the signal they need to deliver top performance.
Easy adjustment
Once connected, the Overdrive makes it easy — turn up the gain knobs until the light indicates 2-, 5-, or 7.5 volt output, and you're all set. Balanced inputs reject noise caused by your vehicle's electrical system, but you can switch to unbalanced operation if necessary. The Overdrive's low-impedance output keeps your signal going strong through long cable runs.
canyouhearmatt
#1 **** talker
canyouhearmatt
South Carolina
canyouhearmatt
