AudioControl DQX Digital Car Audio Equalizer and Crossover
30 Bands of constant-Q equalization to enhance sound quality
Dual, fully adjustable parametric equalizers allow you to select a center frequency, dial in the ideal bandwidth and apply the appropiate amount of boost or cut
3-way 24dB/octave electronic crossover allows you to configure to almost any high performance mobile audio system
Non-volatile memories provides 8 different system settings
24 Bit digital signal processing ensures maximum sound quality
Bright and Dim settings for display
1-year SonicElectronix.com warranty
Products Specifications
Maximum input level: 7.5V RMS
Maximum output level: 7.5V RMS
Output gain: 10dB
Frequency response: 10-22,000 Hz
Total harmonic distortion: 0.01%
Signal-to-Noise ratio: 105dB
Balanced input noise rejection: 60dB
Input impedance: 20,000 ohms
Output impedance: 150 ohms
Crossover slope: 24dB/Octave
Crossover type: 3-way Linkwitz-Riley
Equalization boost/cut: 12dB
Power Supply: High headroom PWM switching
Fuse rating: 2 amp
Dimensions: 7"L x 10"W x 1-1/4"H
sat most of the time I've had it aquired a couple of scratches by doing so
250 shipped obo
only trades would be sundown sa12 d4s, powerbass xta 5k, HO ad244 alt, 100 ft of 0 gauge, deadener, ss mlv, pioneer CD-ID100I +cash either way depending what you have
Output gain: 10dB
Fuse rating: 2 amp
250 shipped obo
