I have pictures of all the items they are new but out of box but havent been used Im looking to get something smaller for my RSX I previously had a larger vehicle and the RSX sounds nice already so If anyone has an offer let me know you can email me for offers and pics @ bigd3000gt@yahoo.com Im also interested in paintball equipment!!! thanks my names Dustin
I got two audiobahn flame q 12"s, AW1006T
Common Features
PHAT 2” Multi-layer Foam Surround
Stamped and Balanced Aluminum Cone
Dual 4 Ohm Voice Coil
2 Ohm or 8 Ohm Operation
Multi-connect Lug Lock Terminals
I have 1 audiobahn A3201t
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
Variable 18dB Hi/Low-Pass Crossovers
Variable Subsonic Filter
3-Way Protection Circuitry
Cobalt Blue Illumination
Blue LED Voltage and Status LEDs
High Gloss Chrome Plated Finish
Nickel Plated Block Terminals
Fan Cooled with Flame Fan Grille
2-Channel Amp Specifications
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 300W x 2
THD at 4-Ohm RMS Power: 0.02%
Bridged RMS Power @ 4 Ohms: 840W x 1
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 10-40,000 Hz
Signal to Noise Ratio: > 100 dB
Dimensions: 17 1/8 L x 12 3/4 W x 2 3/8 H
I also have a flame audiobahn amp A4125H
Features
High Current Circuitry
1-Ohm Stable: 2000W Into 1-Ohm Mono Loads!
Double-Sided Glass Epoxy Circuit Board
Variable Parametric Bass Boost
Remote Bass Control with Blue Backlight Knob
Variable 24 dB High & Low-Pass Crossovers
Variable Subsonic Filter (20-45 Hz)
4-Way Protection Circuitry
VU Meters Indicating Output Response
Secondary Flame-Style Heat Sink
High Gloss Chrome-Plated Finish
Nickel-Plated Block Terminals
Dual Fan Cooled
Multi-Channel Amp Specifications
Amplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 125W x 4
THD at 4-Ohm RMS Power: 0.05%
Bridged RMS Power @ 4 Ohms: 250W x 2
Preamp Outputs: yes
Bass Boost: 0 - 18 dB
Frequency Response: 10-20,000 Hz
Signal to Noise Ratio: >100 dB
Dimensions: 19 13/16 L x 12 W x 3 11/16 H
also a one farad audiobahn capacitor
Common Features
Preamp Outputs: yes
Bass Boost: 0-18 dB
Features
Dual Fan Cooled
Preamp Outputs: yes
