Selling this amp because I sold the rest of my system. I was running 3 orion h2 15.2 subs off this amp no problem. Asking $650.
Features:
These Class D amplifiers are Audiobahn's most power-efficient amplifiers. Drawing less current to put out more raw power, these mono subwoofer amps let you bridge two of them together to combine their power into a single channel. With the smaller design and better power efficiency, you can run these amps all day long without worrying about thermal overload.
2000W x 1 @ 4 ohm mono
3000W x 1 @ 2 ohm mono
4000W x 1 @ 1 ohm mono
Frequency Response: 10Hz-20kHz
S/N Ratio: >100dB (+/- 1dB)
THD: 0.05%
Variable 18dB Low-pass Crossover: 50Hz - 250Hz
Subsonic Filter: 20Hz - 50Hz
Variable Bass Boost: 0 - 18dB
Variable Bass Boost Frequency: 40Hz - 100Hz
Variable Phase Control: 0-180
Class D Circuitry
Multi-Stranded Power Supply Toroids
Double-Sided Glass Epoxy Circuit Board
Remote Bass Control With Blue Backlight Knob
Large Display Volt Meter With Blue Illumination
Throughput RCA Connections
4-way Protection Circuitry: Thermal, Short Circuit, Overload, and DC Offset Protection
Dual Cooling Fans
Cobalt Blue Illumination
Chrome Flame Fan Grilles
High Gloss Chrome-Plated Finish
Nickel-plated block terminals
Remote Mount Bass Boost control with clipping indicator
