I am selling a working EQL series 2 Equalizer, only because my new setup doesn't require it. I hooked it up and tested it. There is a little bit of paint missing off the mounting area and some light scuffs,over spray aside from that everything else is fine
dual 13-band equalizers with level matching controls gray steel chassis with gold-plated RCA jacks top-mounted controls for easy adjustment 2-channel preamp inputs and outputs speaker-level inputs balanced inputs eliminate noise 33 Hz subsonic filter eliminates extreme low bass (rolloff point can be adjusted with optional module) EQ points: 31.5,45,63,90,125,180,250 500,1000,2000,4000,8000,16000 Hz frequency response: 10 to 20,000 Hz signal-to-noise ratio: 110 dB at full output maximum output level: 7.5 volts fuse rating: 2 amps size: 6-15/16"H x8-15/16"W x1-1/4"D
$100 shipped
$100 shipped
