Audio Control DQ-61 As New
wanderer1
Laughlin
Item(s) for Sale: DQ-61 Keep your factory HU
- Speaker Level Inputs: 3 (6 channels)
- Maximum Input (speaker level): 400W per channel at 4Ω
- Input Impedance: 20kΩ
OUTPUTS
- Preamp Outputs: 3 (6 channels)
- Maximum Output Level: 7.5Vrms
- Output Gain: ±12dB
- Output Impedance: 150Ω
PERFORMANCE
- Total Harmonic Distortion: 0.01%
- Frequency Response: 10Hz-22kHz
- Equalizer Frequencies (front/rear): 125Hz, 175Hz, 250Hz, 500Hz, 1kHz, 2kHz, 8kHz
- Equalizer Frequencies (sub): 31.5Hz, 40Hz, 50Hz, 63Hz, 80Hz, 100Hz, 125Hz
- Signal Delay Max (Left/Right): 10ms
- Signal Delay Max (Front/Sub): 35ms
CONTROL
- Remote In
- 12VDC Remote Out (always active when unit is on)
GENERAL
- Power Supply: High Headroom PWM Switching
- Current Draw: 350mA
- Recommended Fuse Rating: 2A
WEIGHTS & DIMENSIONS
- Dimensions: 8.6”W x 5”D x 1.25”H
- Weight: 3.0lbs (1.4kg)
IN THE BOX: DQ-61, ACR-3 Remote, Speaker and Power connectors, Manual, Warranty
•Free iOS Mobile Tools app with DQ-61 Delay module Download_on_the_App_Store_Badge_US-UK_135x40
•User friendly Signal Delay enhances the acoustical alignment between the left and right channels plus the front and subwoofer channels
•Individual equalization controls for the front, rear and subwoofer channels for simple yet precise system tuning
•Six channels of active speaker level inputs – accepts up to 400 watts per channel
•AccuBASS™ – AudioControl’s patented pending processing to correct the bass roll-off in factory source units
•ACR-3 Dash Control Remote allows for control of the subwoofer level plus processing bypass which makes it ideal for demonstrations
•Internal Channel Summing – Easy interface with factory installed amplifiers with built-in crossovers
•GTO™ (Great Turn-On) Circuit – Powers up the DQ-61 when it detects signal on the main speaker level input
•Discrete Input and output level controls
Literally as new, no hesitation 10/10. Great shape and a great piece of equipment.
Price: $260
Shipping and Miscellaneous Item Information: Included
Yeah I just bumped it. You can get a quote, my city and state are listed. it will fit in a large flat rate or a medium flat rate sleeve box for USPS
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line...
wanderer1
wanderer1
Laughlin
jasen1
slater
    May 2, 2024
just call me KeV
    May 1, 2024
