Attaching A Fan
Unless your amp is overheating I wouldn't worry about it - amps get really hot quite often. If it does overheat I'd check to make sure you're running it at a safe impedence with proper heatsink ventilation and with proper settings. If that fails you can run that fan parallel to your heatsink and wire it up to a relay.
no, i wish that was my truck. //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
i thought i would just use the ps2 fan because my ps2 dont work anymore.
the amp has never gone into protection mode yet, so i guess it isn't hurting it. i just cant leave my finger on it for more than 2 seconds sometimes because it's so hot. just got a little worried.
Haha, 2 seconds? That just sounds a little warm! I've gotten a couple burns from two different amps(stupid friends bridging cheap amps at 2 ohms...). Just don't touch it and you'll be ok.
Primo
ibtl
Primo
Grants Pass, Oregon
phrozen5100
