Arc Audio XDi 1200.6: Protect Code 14 - Over Voltage, Alternator Overcharging
HAL3Y SRT
So over the past 2 days, my Arc Audio XDi 1200.6 has gone into protect mode (Code 14 - Over Voltage - Alternator Overcharging) 4 times. It happens when I accelerate from a low speed but also happened once while parked and another while cruising on the highway. Anyone experience this? Leaving it with my audio guy next week while im in the Bahamas so he can get it all fixed but wondering if anyone here knows anything about this. Im assuming I need a new alternator, but not sure.
I drive a 2014 Jeep Grand Cherokee SRT with a stock 220 amp alternator.
1 Arc Audio PS8 with PSC controller
1 Arc Audio XDi 1200.6 to power my front stage (all active Hertz Mille components, 4 ohms per speaker)
2 Arc Audio XDi 1100.1 (running at 1 ohm each) to power
2 Audio Frog GB12D2s
Only the XDi 1200.6 goes into protect mode, both 1100.1s are fine.
Assuming there is a general consensus of what causes a "Overcharging Alternator", any one have any thoughts?
Thanks guys.
find out if it's actually getting voltages too high. hook up a multimeter and drive around to see if it goes above the amplifier protection (probably 15v or more likely 16v considering its arc audio)
newer jeeps might have an electronic voltage reading on the dash if you're not technically inclined
HAL3Y SRT
HAL3Y SRT
St. Louis, MO
wew lad
