Arc Audio Signature Edition 4200SE
Bjames0721
IL
4channels*4 ohms:110 Watts 4 Channels @ 2 ohms:200 Watts 2 Channels @ 4 ohms (Bridged):400 Watts 2 Channels @ 2 ohms (Bridged):400 Watts Frequency Response:4Hz - 100kHzCrossover Range:30Hz - 550kHzCrossover Range X10:300Hz - 5500kHzBass Boost:0 - 15dB @ 20Hz - 80HzS/N Ratio:90 dBInput Sensitivity (Low):.3V - 4VInput Sensitivity (Bal):.4V - 8VMax current draw:222 Amps @ 1600 Watts 20% THDIdle Current:2.3 AmpsDimensions:19.5"(L) x 8.0" (W) x 2.5"(H)8.5/10
Audiophile sound quality based designDesigned by Robert Zeff Class A/B switching design Microprocessor controlled design Microprocessor controlled Code based flashing diagnostics Concealed adjustment controls. Open architecture adjustable crossovers on all channels HP/BP/LP/FP12/24Db per octave selectable crossover slopes on all channels. Internal chassis force cooled speed controlled fan for optimum cooling. Hi/Low level balanced switchblade. RCA inputs for maximum system integrationRJ45. Ethernet input connections for true balanced input connections. Block type terminal connections256 color user selectable illumination circuit. Combined Bias circuit and temperature regulation circuit to regulate bias and lower THD at any point in total thermal cycle. Microprocessor high voltage power supply allows the amplifier to optimize power output at different ohm loads without the loss of efficiency or sound quality. Vdrive based preamp stage improves efficiency lower internal signal loss. Hand picked output devices used on all SE amplifiers. Retail cost of $1449.
Here is a link to the Arc's website where you can do a little more research. SE 4200*| Arc Audio
Used in great condition with minor wear and tear mainly the scuff marks from screwing in the connections. Clean and powerful amp.
$750.00 shipped
Really don't want to sell this but I just got the 4000se changed up my setup a little and was storing this for a back up but it is kind of a waste sitting in my closet. I have the birth sheet, manual, gain control, and bag in the pictures. I Love these amplifiers! It is not modded. Shipping either FedEx ground or UPS ground. I prefer UPS because I've had better luck with them but I'll let the buyer decide. Only paypal payments please. Any other questions please ask and I'll get back to you as soon as I can.
This is still up for sale. I had given up because I really wasn't wanting to get rid of it but was open to it. However, it is a waste to have this not being used. They are awesome amps. I have the se4000 and se2300 as and they are beautiful amps. Let's try for $650.00 shipped.
Also, if someone would like some newer pics I can do that, especially since this is an older thread. It has been sitting in my closet in its packaging. First time I opened it up was today to recheck everything.
Also, I will consider trades or part trade part cash. Looking for a processor, preferably the Arc Audio PS8. BTW I do take paypal.
Bjames0721
Bjames0721
IL
Bjames0721
