Arc Audio SE4200 4CH amp
Bjames0721
IL
Arc Audio Se4200/Price:$500 plus shipping. (Ship via UPS)
Condition
Cosmetic: 8-9
Functionality: 10
Arc Audio SE4200 info:
Audiophile sound quality based design
Designed by Robert Zeff
Class A/B switching design
Microprocessor controlled design
Microprocessor controlled Code based flashing diagnostics
Concealed adjustment controls
Open architecture adjustable crossovers on all channels HP/BP/LP/FP
12/24Db per octave selectable crossover slopes on all channels
Internal chassis force cooled speed controlled fan for optimum cooling
Hi/Low level balanced switchblade RCA inputs for maximum system integration
RJ45 Ethernet input connections for true balanced input connections
Block type terminal connections
256 color user selectable illumination circuit
Combined Bias circuit and temperature regulation circuit to regulate bias and lower THD at any point in total thermal cycle
Microprocessor high voltage power supply allows the amplifier to optimize power output at different ohm loads without the loss of efficiency or sound quality
Vdrive based preamp stage improves efficiency lower internal signal loss
Hand picked output devices used on all SE amplifiers.
Specs:
4 Channels @ 4 ohms: 110 Watts
4 Channels @ 2 ohms: 200 Watts
2 Channels @ 4 ohms (Bridged): 400 Watts
2 Channels @ 2 ohms (Bridged): 400 Watts
Frequency Response: 4Hz - 100kHz
Crossover Range: 30Hz - 550kHz
Crossover Range X10: 300Hz - 5500kHz
Bass Boost: 0 - 15dB @ 20Hz - 80Hz
S/N Ratio: 90 dB
Input Sensitivity (Low): .3V - 4V
Input Sensitivity (Bal): .4V - 8V
Max current draw: 222 Amps @ 1600 Watts 20% THD
Idle Current: 2.3 Amps
Dimensions: 19.5"(L) x 8.0" (W) x 2.5"(H)
In great condition. Was only in my car for a couple weeks. Now it has been resting in my closet. I really don't need it anymore. I have an arc audio se2300, se4100, se4000. This was my spare and I have had a hard time bring myself to selling it.
View attachment 26555535View attachment 26555536View attachment 26555543View attachment 26555538View attachment 26555539View attachment 26555540
FYI:
I have sold a few things on here with no issues. However it has been awhile. Sold an 18 in FI BTL, Term lab, 6 sundown 1500s. All of which there were no problems.
Ref: AlpineAndy, Ben Hemp, vehemtspl, Chris Lacombe.
Bjames0721
Bjames0721
IL
Bjames0721
