Sold Arc Audio, Memphis, MB Quart, Soundstream, RE and more FS
Robertw813
Since I'm getting some new toys it's time to sell off the old gear. I'm not looking for any trades at the moment. I'll include specs to the best of my ability but some of this stuff is getting hard to find.
I don't have many posts as I usually use the forums for the classified section but I do have a couple of refs in the feedback section.
For anyone who is serious about something I can snap some additional pics. If you think the price is to high but are interested feel free to send me an offer. The worst that will happen is I'll tell you no! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll accept just about any payment type (paypal, check, cashier's check, etc.) and will work it out with you via pm.
On to the good stuff:
Memphis CA300-4
75w x 4 @ 4ohm
115w x 4 @ 2ohm
230w x 2 @ 4ohm bridged
Worked like a champ until the day I pulled it out. Has general surface scratches but is in pretty good shape for a used amp.
$125 shipped.
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=MemphisCA300-4.jpg
Arc Audio KAR 400.4
Test Results (taken from: http://www.carsound.com/articles/publish/printer_298.shtml)
Measured output power (At 14.4 Vdc less than 1% THD+Noise): 70.2 x 4 into 4 ohms, 124.2 x 4 into 2 ohms, 248.5 x 2 into 4 ohms bridged.
Measured Current Draw (At Max Power): 27.8 amps into 4 ohms stereo, 47.7 amps into 2-ohms stereo and 4 ohms bridged
Measure Amplifier Efficiency (At Max Power): 70% amps into 4 ohms stereo, 72% amps into 2 ohms stereo and 4 ohms bridged
Measure 1/3 Amplifier Efficiency: 32%
Signal-to-noise dBA (Reference 1 watt): 92 dBA
Rated OutOutput power: 50 watts x 4 @ 4 ohms, 90 watts x 4 @ 2 ohms, and 180 watts x 2 4 ohms bridged
Transient distortion: less than 0.1% @ 4 ohms
Frequency response: 20 Hz-20 KHz
S/N ratio(A wtg): greater than 95 dB
Bass boost: + 18 dB @45 Hz
Input sensitivity: 250 mV - 2.5 V
Crossover: 55 Hz-5.5 KHz variable 12 dB
Fuse: 40A x1
Dimensions: 13 inches x 8.5 inches x 2.5 inches
This as running my components and rear fill up until this weekend. Great amp that worked well in Arizona summers and Massachusetts winters. Very little cosmetic damage.
$185 shipped
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=ArcAudioKAR4004.jpg
Arc Audio KAR 900.1D
350w x 1 @ 4ohm
700w x 1 @ 2ohm
900w x 1 @ 1ohm.
This has been running an RLp-12 @ 2ohm for the last year. Great amp that has been through the same as my 400.4 Very little cosmetic damage. No bass knob with this amp.
$185 shipped.
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=ArcAudioKAR9001D.jpg
SoundStream Angina
100w x 1 @ 4ohm
200w x 2 @ 2ohm
Nice little amp for someone who wants to run a very small sub. Was actually used in my girlfriends car to run a single 8" RE sub. It's probably a 6.5/10 cosmetically and the level adjust knob managed to break somehow, but it still works fine and is completely turnable (you can see it in this picture).
$45 shipped
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=SoundstreamAngina.jpg
MB Quart PCE-216 Components
Frequency response 38-32,000 Hz
RMS Power handling: 130 watts
Max Power handling: 260 watts
Sensitivity 87 dB
Top-mount depth 2-1/2"
MB Quart PCE 216 Includes:
* 2 Midwoofers: PWE160
* 2 Tweeters w/Crossovers: PTE25
Had these installed in pods with the tweets flush mounted in my doors. Good mid bass on these and the tweets get REALLY loud if you are so inclined. I always kept them turned down pretty low. I have all the mounting equipment and grills that these came with (Mounting screws, bolts, etc. not included in pic).
$110 shipped
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=PCE-216.jpg
RE8 Dual 4 Ohm Subwoofer
175w RMS
Brand new, never used. Nice little subs with a good sound.
$50 shipped
http://s39.photobucket.com/albums/e197/robertw813/?action=view&current=RE8s.jpg
That's it for now. When I get around to taking my seats out I will probably have some RCAs, fuse blocks, wire, etc for sale.
Thanks for looking!
I pulled the ZR360 down. I have already ripped out most of the wiring I would need to test it from my car and figured I would crack the case open, break out the soldering iron and try to fix the contacts on the x-over this weekend since I have nothing going on.
Robertw813
Robertw813
Boston, MA
captaincheesey
