Arc Audio KS500.1 mono block
gentlejax
Item(s) for Sale:ARC KS500.1
Item(s) Description/Condition:This is not the mini. this is the class G/H regular. its got some scratches on cover but that means you can easily change color or repaint. cover comes off easily. works fine. tested in my car yesterday.
Price:$200
Item Pictures
$160 shipped weekend bump and specs
This ARC Audio amplifier uses Full Range Class G/H Architecture that significantly improves efficiency without compromise to the sound quality. Don't be fooled by the small size. Class G/H make more power for there size then traditional designs and offer much lower THD and higer damping Factors then Full Range Calass D designs. Very powerfull monoblock for driving your car audio subwoofers.
Features
Mono block subwoofer amplifier
Advanced microprocessor control system
Non digital class H switching design
Code based flashing diagnostics
Designed By Robert Zeff
Protection against: Reverse voltage, Over Voltage, speaker Short, and Thermal Overload
Can drive highly reactive loads
Hi/Low Level balanced switchblade rca inputs for flexible integration into most applications
Optically isolated Mosfet power supply
24dB lowpass crossover with 30Hz to 250Hz
Master/Slave control
Variable Sub Sonic filter
Variable Bass Boost
Quiet Internal Fan cooling
Spesification :
Power output RMS @ 4 ohms 1 x 450 watts
Power output RMS @ 2 ohms 1 x 600 watts
Power output RMS @ 1 ohms 1 x 600 watts
Transient Distortion (400W) Frequency Response 20Hz - 250Hz
S/N Ratio (A wtg.) >112dB
Bass Boost +15dB@10-125Hz
Crossover (Butterworth) 30Hz - 250Hz variable 24dB
Fuse 30A x 2
Size 13.0"(L) x 8.0"(W) x 2 3/8"(H)
gentlejax
gentlejax
Bossier City, La.
gentlejax
