For sale, I have an Arc Audio KS 300.4 amplifier. I'm asking $370 obo. I will ship at the buyers expense to anywhere in the continuous 48 states. I had this in my car for less than two weeks. I wound up having to sell my car after having it professionally installed, and had it removed. My loss is your gain. Practically brand new. Comes in the original box and plastic wrapping with instructions. Please contact me at scsaber29@aol.com, or PM me if interested or have any questions. I can meet around Yorba Linda, but also work in Tustin by the marketplace, so I can meet you around there also. Here are some specs off the Arc Audio website:
* 4 channels of output
* Advanced microprocessor control system
* Non digital Class H switching design
* Code based flashing diagnostics
* Designed by Robert Zeff
* Protection against: reverse voltage, Over voltage, Speaker short, and Thermal Overload
* Very high dampening factor
* Can Drive highly reactive load
* Optically isolated mosfet power supply
* Hi/Low Level switchblade RCA inputs for flexiable integration into most OEM/Aftermarket applications
* Quiet internal forced induction cooling fan
Power output RMS @ 4 ohms 4 x 90 watts
Power output RMS @ 2 ohms 4 x 175 watts
Power output RMS @ 4 ohms bridged 2 x 350 watts
Transient Distortion (100 watts) Frequency Response 20Hz - 20 KHz
Signal to Noise Ratio >95dB
Bass Boost +18db@45Hz
Crossover (Butterworth) 55Hz - 5.5 KHz variable 12dB
Fuse 30A x 3
Size 13.0"(L) x 8.0"(W) x 2 3/8"(H)
Fuse 30A x 3
