Sold Arc Audio ks 125.4 Brand new!
chevyaddict83
Weekend Deal!!!! Buy me a CDA-117, aq2200d,or the saz-1500d, and this is yours!!! I need a deck or an amp, And will take the loss!This amp can be had for under 400$$$$$$$
Selling an Arc Audio KS 125.4. Would like to get 430 shipped, or trade for aq 2200, sundown amps etc, or an upper end deck, 9887,9886,or any upper end alpine that has ipod control,pioneer 88 . o/bo
Power @ 4 ohms 75 X 4 watts
Power @ 2 ohms 125 x 4 watts
Power @ 4 ohms (Bridged) 250 x 2 watts
Signal to Noise 92dB
THD .05
Frequency Range 10Hz– 50KHz
Crossover Butterworth (55Hz – 550Hz)
Bass Boost 15dB 45Hz
Fuse 30A x 2
Size 11.6' (L) x 5.15” (W) x 1.7”(H)
Compact chassis design for small vehicle applications
Non Digital Class H Switching Design
Designed By Robert Zeff
Protection against: Reverse voltage, Over Voltage, Speaker Short, and Thermal Overload
Can drive highly reactive loads
Hi/Low Level balanced switchbladeRCA inputs for flexible integration into most applications
Optically isolated Mosfet power supply
Stable to 2 ohms
The KS 125.4 mini uses a patent pending auto sense turn-on circuit that offers a significant improvement in reliability and operation. No more will the amp unexpectedly turn off in the middle of a song. Instead of relying on the music to supply enough signal to turn on the amplifier on, ARC Audio's new design detects theBTL IC (Chip Amp) used in the majority of stock head units and amplifiers.
To further simplify OEM integration the KS 125.4 mini uses a fully balanced input stage that is switchblade between speaker and RCA input. Simply plugging your stock speaker wires into the RCA's will supply a perfect clean signal to the amplifier and turn it on.
In addition the remote turn on connection, with the flip of a switch becomes a remote turn-on output to connect the rest of your amplifiers.
chevyaddict83
chevyaddict83
medway,ma
chevyaddict83
