Arc Audio DXE - Ultra rare
philray
ARC AUDIO DXE
Gives you complete control from the dash as well and balanced transfer to your trunk.
This is the best possible transport to your amps. PERIOD.
If you are someone who believes that high fidelity matters. This is the gear for you.
4 way active capable
Max input level: 8 volts RMS
Input sensitivity: 8V (0dB), 2V (10 dB), 700m(20 dB)
Max output level: 10 volts RMS
Input impedance: 47.5 K ohm
Minimum output impedance: 600 ohms
Harmonic distortion + noise: Frequency response: +/- 0.2dB
Separation at 1KHz "A" weighted: >78 dB
Signal to Noise "A" weighted: >108dB
Current requirements: 1.2 amps
5 Filters with +/- 15 dB at 20Hz-50Hz with Q of 2,50HZ-100Hz with Q of 1.4,100Hz-1KHz with Q of 1.1,1KHz-10KHz with Q of 1.1,10KHz with Q of 1.1.
Description:
In the future all audio products will have the flexibility of a fully Digital Control System with the sweet smooth sound and perfect sound stage of an Analog Device. This was our goal when we set out to build the DXE. We use an advanced digital controller to operate all the features of a sophisticated Analog Crossover. The result is the channel tracking and frequency control of a fully digital crossover without the harsh mechanical sound that can accrue. For years home audiophiles have enjoyed Hi End Analog Systems that produce stunning sound stages and smooth harmonics. Now the DXE brings this level of performance to the car with the control of a fully digital crossover.
This truly Audiophile Crossover is coupled with a 5 Band Parametric Preamp EQ with fully balanced output and a Digital Control.
Features:
• Max input level: 8 volts RMS
• Input sensitivity: 8V (0dB), 2V (10 dB), 700m(20 dB)
• Max output level: 10 volts RMS
• Input impedance: 47.5 K ohm
• Minimum output impedance: 600 ohms
• Harmonic distortion + noise: • Frequency response: +/- 0.2dB
• Separation at 1KHz "A" weighted: >78 dB
• Signal to Noise "A" weighted: >108dB
• Current requirements: 1.2 amps
$750 and considering trades
buyer pays actual shipping
philray
philray
United States
philray
