Arc audio 900.6 $300.00 OBO
MutantDreams
Item(s) for Sale:Arc Audio 900.6
Item(s) Works great, Missing a hex screw on the 6th channel negative post thing, and the plastic piece for the input level control on the sub 2 ch. Comes with bass remote, and a arc audio crossover.:
Price:$300.00 Obo +S&H
Shipping and Miscellaneous Item Information:Ill be shipping from the area code 31907, local pickup is allowed.
Item Pictures:View attachment 26532364
I was looking at this and checked the specs, not quite what I'm looking for but nice amp. Here ya go:
KS 900.6 - ARC Audio 6 Channel 550 Watt Amplifier
Description:
Advanced Microprocessor control system
Code Based flashing diagnostics for faster trouble shooting
Optional center channel
2/4/5-6 channel input options and source selection switches
Block style terminations
12dB butterworth crossovers (all channels)
Front + Rear Channels (High pass and Full Range)
Sub + Sub Bridged on channel 5+6 (Full Range and Low Pass only)
Center Channel #6 (Full Range and high pass only)
Specifications:
Power output RMS @ 4 ohms: 4 x 60 watts
Power output RMS @ 2 ohms: 4 x 100 watts
Power output RMS @ 4 ohms (Sub Channels only): 2 x 155 watts
Power output bridged @ 4 ohms 2x120 watts: 2 x 120 watts
Power output bridged @ 4 ohms (Sub Channels only): 1 x 550 watts
Transient Distortion:
Frequency Response: 20Hz - 20 KHz
Signal to Noise Ratio: >77dB
Bass Boost: +15dB @ 45Hz
Crossover (Butterworth): 55Hz-5.5KHz var - 12dB
Fuse: 25A x 4
Size: 19 1/2"(L) w 8.0"(W) x 2 3/8" (H)
MutantDreams
MutantDreams
Columbus, Georgia
arthurk
