Arc Audio 4150XXK and 2500XXK
throatrattling
Canadian Guy
I would rate the amps at 7/10 cosmetic. They've got some nicks and scratches but still clean up well.
Function is 10/10. These are two of the cleanest amps I've used, and they have some serious power as well.
450 Shipped for the pair. Would like to keep them together unless I have a buyer for each, in which case they'll be $240 shipped each.
4150XXK:
80 watts x 4 @ 4 ohms, 160 watts x 4 @ 2 ohms, 320 watts x 2 @4 ohms bridged
Microprocessor controlled
Remote digital bass boost gain w/led status display
Set and forget crossover switches on bottom plate
Seperate front and rear high/low/full range select switch
Seperate front and rear mono/stereo/full range select feature
Heavy duty construction
Thermal, DC, offset, reverse voltage, over voltage, short circuit protection
Signal to Noise Ratio: 107dB
Frequency Response: 20Hz - 20KHz
Made in U.S.A
Dimensions: L16" x W8" x H3.35"
2500XXK:
270 watts x 2 @ 4 ohms, 525 watts x 2 @ 2 ohms, 1050 watts x 1 @4 ohms bridged
Highly efficient 4 layer PCB
Rated 250 amp per channel output devices
Uniquely designed high efficient power transformer
Variable speed fan control for quiet operation
Rated 500 amp power supply switching FET
Power save mode for low level playing time with engine off
Protection against: reverse voltage, over voltage, speaker short, and thermal overload
Signal to Noise Ratio: 105dB
Made in U.S.A
Dimensions:18"L x 8"W x 3.35"H
throatrattling
Canadian Guy
throatrattling
Toronto
johntharkins
