frankiebones
the specs on the arc audio are weird, considering it is a very sick 2 channel.
Output power : 270x2@4 ohms, 525x2@2 ohms, and 1,050x1 4 ohms bridged
Transient distortion :
Frequency response: 20Hz-20Khz
S/N ratio(A wtg) : > 105dB
Bass boost : + 18dB @45Hz
Input sensitivity : 250mV - 2.5V
Crossover : 12dB/24dB stereo 55Hz-5.5KHz
Fuse :
30A x3
Dimensions : 18" x 8" x 2.35"
so with a pioneer HU that gets not close to the 5V preamp output it promises, but certainly gets over 2.5V, i could not use this beautiful amp?
also, i think this amp would be good either to run my morels passive with 270 going to each side, which is about what they are getting from my kicker kx650.4 bridged.
OR, i could use it to power just the woofers and go active. the RMS of my 6" hybrid ovation woofers is 160 W. the max. transient power handling is 600 W.
from what i think i understand, the woofers will see a 2 ohm load at points bc the impedence of the speakers changes as the cone moves. the 525W this arc puts out at 2 ohms is pretty close, dont u guys think?
Fuse :
30A x3
