Hey I have a Arc Audio 1500 XXK, but I realize its a bit too much power for me, so I'm willing to sell it to save some money and step down...heres the description:
# Class A/B Monoblock Subwoofer Amplifier
# RMS Power Rating:
* 4 ohms: 510 watts x chan.
* 2 ohms: 1000 watts x chan.
* 1 ohm: 1000 watts x chan.
# Variable Bass Boost Frequency: 30Hz - 125Hz
# Designed, Engineered and Assembled in the USA
# Various Protections: Short Circuit, thermal, reverse voltage, over voltage and DC offset
# Built-in variable 12 dB per octave Crossover
# 12db or 24dB per octave subwoofer crossover
# Crossover Range: 55Hz - 5.5kHz
# CEA-2006 Compliant
# Preamp output and Preamp input
# Very high damping factors
# 4 gauge power/ground leads
# Fully regulated power supplies produce full power output with battery voltages as low as 12 volts.
# Symmetrical, discrete power amplifier circuitry
# Engineered to drive highly reactive loads
# Microprocessor controlled power supply and protection circuits
# Dimensions: 17.5"L x 8"W x 3.35"H
so obviously its a very nice amp (arc amps are also usually underrated) and will make any sub shine...looking to get $330 (or best offer) shipped and insured...let me know if your interested.
I have several refs on here, and my ebay feedback (dkuchenski) is 100% positive...I could even set up an ebay auction if you'd like.
# RMS Power Rating:
