W whammybarallsta Junior Member 9 0 OC/LA Apr 11, 2008 #1 need a new sub amp, running @ 1 ohm to 4 12" type R. AQ's prices are really good, but at the same time I'm not scared to buy the RF. What do you guys think? Click to read more...
bumpin buick 5,000+ posts Science is everything 11,523 9 Appleton, Wisconsin Apr 11, 2008 #2 T20001bd all the way, will put out about 2500-2600wrms so the subs would see like 650wrms each. Also they look sexier imo
3 350zspl 10+ year member CarAudio.com Veteran 4,241 11 WPB Florida Apr 11, 2008 #3 my t20001bd did 2200 x 1 @ 2 2850 x 1 @ 1 i know the aq wont do that but it also does not cost as much
bumpin buick 5,000+ posts Science is everything 11,523 9 Appleton, Wisconsin Apr 11, 2008 #4 theres one right now for 400 if you dont mind used
dbhittin 5,000+ posts Banned 7,142 2 Van...Wa Apr 11, 2008 #5 get 2 aq2200... im gonna be running 4 type r's too
bumpin buick 5,000+ posts Science is everything 11,523 9 Appleton, Wisconsin Apr 11, 2008 #6 get a T40001bd and then see whats up
xtremebassjunky 10+ year member Is it ever loud enough? 4,002 0 Charleston, SC, (Oklahoma) Apr 11, 2008 #7 unless people clamp the amps and compare that to what you see on a birthsheet... I don't trust birthsheets. AQ is cheaper and I bet it is every bit as powerful as a t20001 as far as a possible couple hundred watt difference... that is too small a difference to be heard at 2000w+... it's inaudible.
pioneerpimp 5,000+ posts CarAudio.com Veteran 6,718 0 IL Apr 11, 2008 #8 aq has some tests that look pretty close to that. look them up.
