AQ2200D or MMATS D-2100.1
I have a Mmats 2200.1 and the Aq 2200D, I have clamped both and they are very close. Less than a 30 watt difference with a slight edge to the MMats.
write the results here are u nice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how´s it going DBDRAGGUY?? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
the AQ has a clip indicator on its remote gain, fyi.....nice lil feature. i'm betting the 2 are neck and neck are far as output and quality.
wow i did not know it has a clipping indicator thats NICE! //content.invisioncic.com/y282845/emoticons/drool.gif.b5e863e893038027711d4402f340dad0.gif
Im going with either a AQ 3500D or two AQ 2200ds for my CRX, i have not found a amp/s out there to do what these amps do for the price, even tho i dont know much about the 3500 yet but seems like it will do all of its rated power then some, i think AQ has one of the best lines of equipment out right now, the price, customer service, and for what you get for the price its going to be hard to beat the AQ 2200D!!
look what i found.
From dj
You can set the gain with the REMOTE GAIN CONTROL BY DOING THE
FOLLOWING.FOLLOW THESE INSTRUCTIONS TO THE LETTER
1. LEAVE THE HEADUNIT OFF
2. HOOK UP THE AMP AND SUBS TO THE AMP
3. PLUG THE REMOTE GAIN CONTROL TO THE AMP
4. MAKE SURE THE MASTER/SLAVE SWITCH IS SET TO MASTER
5. SET THE SUBSONIC FILTER TO 30, SET THE LPF TO 100
6. SET THE GAIN ON THE AMP HALF WAY UP
7. TURN THE REMOTE GAIN KNOB COUNTER CLOCKWISE TO OFF
8. TURN ON THE HEADUNIT AND SET VOLUME 2/3-3/4 UP
9. INSERT CD OR TUNE TO MUSIC, AT THIS TIME YOU WILL GET NO OUTPUT FROM
AMP BECAUSE THE REMOTE GAIN IS TURNED OFF
10.SLOWLY TURN THE REMOTE GAIN KNOB CLOCKWISE UNTIL THE CLIPPING
INDICATOR LED BEGINS TO SLOWLY BLINK ON AND OFF, IF THE CLIPPING
INDICATOR LED GLOWS STEADY TURN THE REMOTE GAIN KNOB DOWN UNTILL THE
CLIPPING INDICATOR TURNS OFF OR JUST SLOWLY BLINKS
IF THE CLIPPING INDICATOR LIGHT DOES NOT COME ON WHEN THE REMOTE KNOB IS
TURNED ALL THE WAY UP TURN THE REMOTE KNOB COUNTER CLOCKWISE TO THE OFF
POSITION AND INCREASE THE GAIN SETTING ON THE AMP TO 3/4 AND THEN REPEAT
NUMBER 10
THE REMOTE GAIN CONTROL WILL NOT ALLOW YOU TO TURN THE GAIN BEYOUND THE
GAIN SETTING ON THE AMP. IT ACTUALLY IS A GAIN TURNDOWN CONTROL
WHEN YOU CHANGE THE VOLUME SETTING ON THE HEADUNIT, ADD BASS BOOST OR
CHANGE MUSIC THE POWER REQUIREMENTS TO THE AMP CHANGE AND THE AMP COULD
CLIP OR EVEN NOT PRODUCE ENOUGH POWER. All you have to do to make sure
the amp is correctly set is monitor the remote gain clipping indicator
and turn the remote gain knob up or down until the clipping indicator
light is off or just blinking now and them. If the clipping indicator
led stays on the amp is clipping and you need to turn the remote knob
down.
If you have a problem with the install STOP what you are doing and call
for help.
sjobas
sjobas
sweden
Jam1e
