aq vs hca
which amp is better based on specs
AQ1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dash Mounted Remote Included
Dimensions 12.75"(L)x9.27"(W)x2.35"(H)
HCA 2400D
Directed’s patent pending ESP®(exc. model HCCA-D600)
Massive loosely-regulated MOSFET power supply
IntelliQ Bass Optimization Circuit and Remote Gain Control (Models D1200, D2400, D5000)
# Heavy Gauge Direct-wire High Current Power and Speaker Terminals 18dB/octave Low-pass Filter
# Class D Mono Block Amplifier CEA Certified Specifications
# Power 13.8V
# Briged Power 1 X 425 RMS 4 Ohm
# Briged Power 1 X 800 RMS 2 Ohm
# Briged Power 1 X 1200 RMS 1 Ohm
# Frequency Response 20Hz-250Hz
# THD+N
# Damping Factor >50
# S/N Ratio 57dBA
# Crossovers Low Pass Selectable 12/24 dB
# Input Sensitivity 200mV - 5V
# EQ Circuit Intelli Q 10 dB
# Remote Level Control Included
# Protection Thermal, DC Offset, Revers
Magnatus
Banned
Magnatus
AZ
n2audio
