ascitiesburn69
Im buying a 12" HDC3 in few weeks and will build a 2.5net box rear firing at-37-38hz with 3" wide port and using a AQ1200d to power it. Dimensions are 35"Wx14"Hx15"D. I was wondering if anyone knew off hand how much one weighs? and would i need a double baffle for sure? or would a single baffle be fine? Also im gonna use all-thread for bracing most likely and was wondering if one say .75" piece front to back would be enough or two would be necessary? planned on two but also could use the 5$ on mcdonalds or BK for the build day //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Is bracing the top to bottom necessary as well? using like 2x2's or dowels?
