AQ 4x90
RRR37
Audioque 4x90 4 channel amp
In excellent condition, couple tiny scratches 9/10 cosmetic - 10/10 mechanical. I have gone with a bigger amp for about double the power so I will not be needing this one, which is the only reason for selling.
SPECS:
Input Sensitivity 0.2V ~ 8V
Signal to Noise Ratio 100
Damping Factor 250
External Fuse Rating 2 x 30Amp
Tested Voltage and THD 14.4V & 1% THD
4 ohm Power 90W x 4
2 ohm Power 120W x 4
4 ohm Mono Power 240W x 2
Channel 1 and 2:
Variable X-over 45 Hz (450Hz) ~ 450Hz (4.5KHz) at 12dB/Oct.
X-over Multiply x 1, x 10
X-over Selector Clone 3/4/FULL/HPF
Channel 3 and 4:
Subsonic Filter 10~360 Hz at 12 dB/Oct.
Bass Boost 0~12 dB
X-over Selector LPF-BP /HPF-FULL
Outputs Line Out
Dimensions (mm) 350mm (L) x 238mm (W) x 59.6mm (H)
Dimensions (in) 13.78in (L) x 9.37in (W) x 2.35in (H)
170 shipped
I'm not really looking for trades, but might consider if it's too good to pass on. I need a big alt and this will be going to fund that.
Tracked and insured to lower 48. Will be double boxed and padded in original Audioque packaging.
RRR37
RRR37
Puyallup, WA
RRR37
