Sold Aq 2200 for sale
akmarcos20gauge
Sup guys have an Aq 2200 or sale cosmedically 10/10 mechanically 10/10 strong amp great condition 300 shipped sorry I'm at work I'll take pics with username tonight have original box and all
Model AQ2200D
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Remote Level Control
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V 2500 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions
those r the specs and I'll do confirmation pics when I get Out of wrk later. Ref r listed and I also just bought a nightshade from bobby32
how many watts at 2 ohm for one sub? just making sure this isnt too much power for my one sub and specs doesnt list that info. thank you
you can always keep the gain turned down on the amp itself, just don't turn your head unit to 45/45 volume for example and clip it to shit. Just use common sense and you are fine. You are better off getting a bigger amp NOW so you have room for upgrades in the future which you wold have with the aq2200d as you can run it at 1ohm later on the subs you desire.
Remember you can have a 3500rms amp and set the gain down to 1500rms (for example or lower if you wanted) and it is perfectly fine. Just use a dmm and set the gain to the power you want..
akmarcos20gauge
akmarcos20gauge
Tyler,TX
AngryOscar
