AP-3002 vs AQ750D
iDefiant
which would be prefered with a single SSA DCON 12D4 in a volkswagen rabbit hatchback
-Audiopipe AP-3002
160W x 2Channel @ 4 ohms
320W x 2Channel @ 2 ohms
640W x 2Channel @ 4 ohms
(max: 1500W)
OR
-Audioque AQ750D
Output Power 14.4V @ 1% THD
300W x 1 Channel @ 4 ohms
500W x 1 Channel @ 2 ohms
750W x 1 Channel @ 1 ohm
Output Power 14.4V @ 5% THD
1000W x 1 Channel @ 1 ohm
-Audiopipe AP-3002
(max: 1500W)
OR
-Audioque AQ750D
for the AP-3002 its 640W x 1 channel @ 4ohms
Save up and get the AQ, it's a world of better quality. And yea, the AP does 640 @ 4 ohms bridged to mono.
While the AP's do rated power, the end to be very inefficient. And the AQ's tend to do more than rated, and rather efficiently. Might also want to look into an eD NINe.2x if you don't mind buying used.
Also consider these, a bit cheaper than the AQ.
(-NEW-) Soundstream Rub2.600 600 Watt 2-Channel Amp With Bass Knob Rub2600 on eBay!
Amazon.com: Soundstream RUB1.700 1x400 Mono Block Amplifier (Blue): Car Electronics
I agree look into the soundstream rubicon series those are good amps, also look into MB Quart Onyx or Discus series amps.
MA Audio makes some decent budget amps too. I wouldn't consider AQ to be a budget amp but yeah they are definately good amps. pricey though for a college student on a budget...might be something you have to find a good deal on used.
iDefiant
iDefiant
College Station, Texas
i2ain2thunder
