anybody have any play time or input about the prv ad4000.1?
ive had good results with my taramps lol try not to talk too badly about it until you've run one yourself //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
btw mmats makes some of their small amps using the same methods as brazillians, but obviously better more stable designs.
I know there's some small footprint amps that can put out rated but they are not overbuilt like the Koreans... You buy a twisted sounds 3.5 your really buying a 4.5kw amp at 14v
Full bridge amplifiers are tried and tested. If you actually feed your amplifier the voltage you're suppose to and don't run lower then the recommended impedance it's more power for the money.
Edit: I can't speak for this brand but there are a few trusted Brazilian brands that rarely fail when treated right. Yes Koreans handle more abuse but why not treat it right in the first place..
I've been looking into them twisted sounds amps. Do you own one ?
I own the 1.8kw and it will do over 3k at 1ohm with voltage between 15and 16... They dynod it at 3900 .8 ohm 15.8v so if I get a dual 1 ohm beast 18 and run .5 she's gonna put out
Dude you can defend these Brazilian amps to the death but id still trust an unknown Korean amp way more than I'd ever trust one of these fragile Brazilian amps all day everyday... Look into the fsd amps if you want to gamble... Go to twisted sounds if you want an amazing solid amp at normal voltage... They turn into a whole new Beast above 15v
You can talk trash on brazilians all you want but unless you actually tried running one, your opinion does not mean much.
Lets look at it this way. You have 600 bucks for a used amp. You dont want to go .5 ohms you just wanna wire to 1 and keep it simple fk caring about box rise and ****, this is daily. No one other than hardcore competitiors will run anything other than a normal 12V to 15V charging range.
Only thing you can afford is a 3-4k amp Or hell that FSD 5k amp. On the other hand, you can get a taramps 8k or banda 7k. If you just use the amps the way they were designed to be used, it'll work fine. Initially I was scared making the switch from my dc 3.5k to a banda 7k. I was just like you thinking brazilians are sh*t because of how small and underbuilt they are. Reminding me of my worst amp purchase ever, the american bass vfl 4480.1 which didnt perform for ****. However I had spare money so i was like fk it i'll try it out, if anything i'll sell it for what i paid for it.
For the money there is no way the dc 3.5k could even hold a candle to the banda performance wise and loudness wise. The bass even sounds cleaner on the banda after the switch and i'm at 15% gain and -4 sub level setting the gain for only 4.5k rms on the dmm, not even tapping into what the amp can actually do yet or rather the subs bottom out if I push just one more notch. I'm way louder along with having less voltage drops with a lot more head room then i could dream of. Plenty of local people will vouch how much of a gain I got going from dc 3.5k to the banda. Amps run cool during hot 100 degree+ weather too with the 4 push pull fan configurations.
Its already known that Brazilians arent meant to be wired anywhere below their impedance and these fkers testing the amps put them in ridiculous situations where the amp was not meant to perform in and then talk **** all over it.
Unless you are wiring hella low with a korean, you are still gonna face the same box rise issues no matter what. The FSD will not put out 5k if you wire it to 1 ohm. After rise, it'll put out the simlar amount to a brazilian 5k. The only way its gonna make 5k is if you wire to .5 or lower which kills effiicency anyways.
Apples to oranges. One appeals to people running normal 12 volt systems and wire to 1 ohm nominal. and the other caters to people that completely abuse the **** out of their amps wiring extremely low and running 16/18volt systems.
For the money there is no way the dc 3.5k could even hold a candle to the banda performance wise. The bass even sounds cleaner on the banda after the switch and i'm at 15% gain and -4 sub level setting the gain for only 4.5k rms on the dmm, not even tapping into what the amp can actually do yet.
Its already known that Brazilians arent meant to be wired anywhere below their impedance and these fkers testing the amps put them in situations where its not meant to perform and then talk **** all over it.
I paid 3hundo for my 1.8 that's capable of high 3k easily that's quality at a low price... The battle with box rise can be won... When I get around to running that much power it's gonna be on a 1 sub setup and correct me if I'm wrong but it should be significantly easier to have minimal box rise on a single sub compared to multiple sub set up
The thing is, I dont care about the rise that much and i dont care about .5 ohm and lower operation either. I care about the output and the banda over- delivered and the DC is kicked out and sold ASAP. Electrical system is happy about the change too. not even a single tenth of a voltage drop compared to the .5 drop the dc had while being way louder.
Hey if your Banda outperformed your DC that's cool man what banda and DC are you comparing
DC model used is stated in my earlier big post which is a 3.5k and the banda 7k is in my sig. Both cost the same new retail and used. Might not be overbuilt but it sure is bang for buck wise, Amp shows no problems reliability wise yet, I got it off boomsday who ran them for a few years too.
You will not get high 3k form that 1.8k //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
You will not get high 3k FROM that 1.8k //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
yep Unless he .125 ohm burp it on 16 volts.
coogismoove
coogismoove
cocoa,fl
Massive spl
