Any C++ Programmers...
solidcrowd
I need help fixing this program for my class HW. I'm getting problems trying to total everything up...Heres the Program. It's fine up until- cout
and cout
// This program calculates the total ticket sales after each game.
#include
#include
#include
using namespace std;
int main(int argc, char *argv[])
cout
double boxprice, boxsold;
double sidelineprice, sidelinesold;
double premiumprice, premiumsold;
double generalprice, generalsold;
double totalsold, totalamount;
cout
cin >> boxprice;
cout
cin >> boxsold;
cout
cin >> sidelineprice;
cout
cin >> sidelinesold;
cout
cin >> premiumprice;
cout
cin >> premiumsold;
cout
cin >> generalprice;
cout
cin >> generalsold;
cout
cout
cout
cout
system("PAUSE");
return EXIT_SUCCESS;
Code:
cout << totalsold = boxsold + sidelinesold + premiumsold + generalsold;
cout << totalamount = boxsold * boxprice + sidelinesold*sidelineprice + premiumsold *premiumprice + generalsold * generalprice;
Just as a lil FYI, you can put code segments like (code) (/code) (except with the brackets).
Onward. It doesnt work because you cant set a value on a cout statement, you can add them in the same place, but can't set the value.
Here's what you could do
Code:
cout << boxsold + sidelinesold + premiumsold + generalsold << endl; //so it goes to the next line
cout << endl << boxsold * boxprice + sidelinesold*sidelineprice + premiumsold *premiumprice + generalsold * generalprice << endl;
or
Code:
cout << totalsold << endl << endl << totalamount;
EDIT: OOOH, read the rest of the program. cout means console out, which will only display text in the console window. You don't have to use cout to set values. So you can just get rid of the cout and it'll work.
Also, why are u getting arguments through the main? I dont recall needing arguments in C++. At the end of the program you can also just put "return 0;" instead of pausing the computer then exiting. You can also set all the double values in one line like
Code:
double boxprice, boxsold, sidelineprice, sidelinesold, premiumprice, premiumsold, generalprice, generalsold, totalsold, totalamount;
Code:
totalamount = (boxsold * boxprice) + (sidelinesold*sidelineprice) + (premiumsold *premiumprice) + (generalsold * generalprice);
solidcrowd
solidcrowd
Buffalo, New York
FurbiesAndBeans
