ok so i think i have decided instead of jus getting a voltage regulator to step to 16 volts im just going to buy a 140amp 16volt alternator from powermaster, my plan is to keep my current alternator for the cars electrical and mid/highs amps, and use the 16volt alt just for the sub amp, ill have to fabricate a second bracket for the 16volt alt, but i dont think that will be a problem. but would this work, im sure it would but would a 140 amp alt be sufficient to run we'll say around 5700wrms, with 4 kinetik hc16v batts, the sub amp will be a soundstream xxx10000d. thanks in advance to all information guys.
