amplifer input sensitivity?
If it's too much, just turn the volume down, and tune at a lower volume //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Some amps say that there low level input is like 0.2 to 4.0 volts and i was wondering if that would work with my hu since it has 5 volt preouts? I think that even at the lowest gain setting it will still be to high.
Heres a link: http://www.millionbuy.com/apnpdx2150.html
Due to the nature of music, and gain matching it's no issue. The hu only puts out that voltage when the hu is at max volume, usually only while playing a 1k test tone. If you set your gains at volume at less than a max hu volume, your HU cannot put out that voltage, unless you turn it up to where your amps will be clipping anyway. Combine that with the fact that music will only really usually be taking 1/10 of your voltage at a given hu volume vs a test tone at that volume and you have NO issues.
hondarider
hondarider
glidden, IA
T3mpest
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
