Ameican bass 1100.1
cal
AB VFL 1100.1 12V VERSION
Item(s) Description/Condition: 1 ohm Stable Class D Mono Block Amplifier
Low Level Input and Output
Frequency Response: 20Hz ~ 350Hz
Input Level: 0.2V ~ 6V
Variable Subsonic: 10Hz ~ 50Hz
Variable Low Pass Filter: 35Hz ~ 250Hz
Variable Bass Boost: 0~ 9dB at 45Hz
Remote Gain Controller
Two amplifier Linkable Connector and Controller
12,500 Watts RMS
Width: 9.5"
Height: 2.25"
Length: 36"
amp is used but clean and fully working , the amp was repaired by previous owner due to water causing fets to blow . from what i was told all fets on power supply side were replaced to match and gate resistors were replaced as needed . i tested the amp and its fulling working i also had a shop bench test the amp and they confirmed amp has been repaired to factory specs and @ the time of inspection needed a new fan and that has been replaced as well. the only reason im selling work is slow and build is slower lol.
1350 picked up 1450 shipped con u.s. and price is firm atm,
no trades
badd *** amp!!!!!
i have the VFL200.1 but im wondering if it will do 0.5 ohm daily??
im hooking it up to 4 4ohm 12's running parallel will give me 0.5 ohm...
or will i burn up the amp?? i have the power to run it 2 alts and 3 batteries...
always stays above 13.5 volts
idk any advice???
ok since pepole are pm about trades i will entertain for either a single 7k amp or 2, 3.5k strapable and cash on top and needs to be in my favor . please dont ofer me 5 amps to add up to what i need or a bunch of stuff i dont need
cal
cal
cal
